Hi and welcome back.
It is possible to get a bad thermostat. However, when the engine is hot, are all the coolant hoses hot too?
If you want to check the thermostat, remove it from the vehicle. Boil water and drop the thermostat into the boiling water. You should see it open. If it does not open or open fully, it is bad.
Also, a bad radiator cap can cause an engine to overheat. The boiling point of coolant, water increases when its under pressure. Check that too.
Chances are you do not need this, but here are the directions for replacing the thermostat just in case. The pictures attached correlate with these directions.
_____________________________________________
REMOVING AND INSTALLING/REPLACING COOLANT THERMOSTAT
Remove fan clutch with fan impeller and fan cowl, refer to Fan Clutch, Service and Repair.
Drain and dispose of coolant. See: Coolant > Procedures
Note: The water drain plug is located on the exhaust side on cylinder 2 in the engine block.
Installation:
Replace sealing ring of water drain plug.
Tightening torque, refer to Specifications, Mechanical.
Vent cooling system and check for leaks, refer to Cooling System, Service and Repair. Pull locks and disconnect water hoses.
Installation:
Refer to general instructions for work on cooling system, refer to Cooling System, Service and Repair.
Loosen nut (1).
Release screws on thermostat housing, remove thermostat housing.
Installation:
Keep sealing faces clean and free of oil.
Note: Coolant thermostat is integrated in coolant thermostat housing and can only be replaced as a single unit.
Installation:
Replace gasket (1).
Please keep in mind, a bad head gasket, plugged catalytic converter, and other things can cause the engine to over heat. Here are links for testing both the converter and the head gasket.
Let me know if any of this helps.
Sep 23, 2018 at 6:57 PM
