Will not start all you hear is a clicking noise?
2009 JEEP LIBERTY
60,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
TOM SESSLER
When you turn the key all you hear is a clicking noise. Have replaced the battery. Had taken off the starter and had it checked and was told it was good.
Sep 10, 2025 at 11:17 AM
Can you upload a short video of the noise so I can hear it? You can upload here in your response. We should make sure the engine is not locked up, this video can help you:
https://www.youtube.com/watch?v=oN42gZN6gOE
Also this video may help us as well:
https://www.youtube.com/watch?v=6YRW8fyNudY
Let us know what you find.
Sep 10, 2025 at 5:28 PM
STEVE W.
  • 15,113 POSTS
Being a Chrysler and especially a Libby I would look at the grounds, there is one from the battery to the lower left of the engine block and one to the body, the one to the body is very susceptible to corrosion. It is located near the battery. Remove the nut, clean up the area and the cable, reinstall. See if it does more than click The one on the block is a bolt, it corrodes because it's a copper eyelet, between a steel bolt going into an aluminum block. I try to save them but usually the bolt breaks off. Not really a problem as there are a few other places you can bolt it to on the engine.
Sep 10, 2025 at 5:39 PM
