After replacing the radiator, the car will not start?
1998 OLDSMOBILE CUTLASS
180,000 MILES • AUTOMATIC
AMO145
Hi, I had someone change my radiator and now it doesn't start. It sounds like it ran out of gas but has gas. Can someone please help? Thanks in advance.
Mar 12, 2023 at 2:18 PM
There is a chance that the crankshaft position sensor was disconnected or damaged when the radiator was being installed.
Do me a favor. Check to see if there is spark to the plugs.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know what you find.
Mar 12, 2023 at 3:25 PM
AMO145
Can you please send me a picture please of where it's at? because I feel like he connected stuff wrong. I know very little about cars but I'm willing to learn and try because I can't afford to take it to a shop. Thank you, I appreciate your help.
Mar 12, 2023 at 3:32 PM
The sensor is at the front of the engine. I attached a pic below showing it, but the pic is from my manual and is somewhat vague.
In the pic, you are seeing the front of the engine without everything attached to it. Things that are missing are the belts, alternator, p/s pump, and so on.
I highlighted the crank sensor and the connector. When you look for this, look all the way down at the bottom of the engine where the belt is driven by the crankshaft pulley. See pic 2.
Let me know what I can do to help you.
See pics below.
Mar 12, 2023 at 6:40 PM
AMO145
Thank you, I will try that. I'm going to send you a picture in the morning in hopes you can tell me where this part goes because I know it does not connect to the radiator where he has it. Also, I think they are called vacuum lines that are not connected towards the windshield either. I'm pretty sure that's why it's not starting as well. But I know.
Mar 12, 2023 at 9:03 PM
Sounds good. The vacuum lines will at least cause a rough idle. If there are enough disconnected, it could cause a no-start.
Let me know. I'll watch for the pictures.
Mar 13, 2023 at 8:00 PM
