After replacing the clutch it shut off while driving
2003 HYUNDAI TIBURON
168,319 MILES • 2.7L • V6 • 2WD • MANUAL
ROBERT MASTEN
We changed the clutch and was going on a test run and started out the drive way and it just shut off, but will start with starting fluid. can somebody help?
Jan 5, 2020 at 7:03 PM
TOUGHDIVER
  • 224 POSTS
It is possible there could be loose ground wire connection recheck all the ground wires connections and plug in connectors you unplugged when removing the transmission, or it have blown an ECM or fuel pump fuse or relay. I'm attaching fuse block details and links below for you to reference. Please let us know if this was helpful and what fixed the vehicle.
Jan 7, 2020 at 1:31 PM
