Most commonly when this happens, it is either a fuel or ignition-related issue. So, let's do a couple simple tests.
First, see if the engine will start if you use starting fluid. If it does and then stalls, we know it is fuel related. If there is no change, then we likely have an issue with the ignition. At that point, we need to determine if there is spark to the spark plugs.
Here is a link that explains how that is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try this and let me know the results. Additionally, the vehicle has a timing belt that may have failed. If you could record it cranking and upload it for me to hear, I should be able to tell if that is the case by hearing it.
Let me know what you find.
Jul 25, 2022 at 9:58 PM
