Will not after changing out the water pump and timing belt
2004 KIA OPTIMA
125,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
CLAY CRUM
MEMBER
1 POST
FOLLOW
Changed water pump and timing belt now car turns over but does not start.
Feb 17, 2017 at 4:04 AM
HMAC300
CERTIFIED EXPERT
if the battery was disconnected try a security system reset. It may have set it off. I am assuming that the timing belt was lined up correctly and engine was not turned over after belt was removed. if it was you may have bent valves. See link. https://www.2carpros.com/articles/how-to-reset-a-security-system
