no sign of any electricity going to the car?
2003 VOLKSWAGEN BEETLE
102,000 MILES • 2WD • AUTOMATIC
EASTONKG
I have a VW convertible beetle that was working fine. I got home and parked the car. to make sure all the windows were rolled up I pulled up the window switch to roll up all the windows (all the windows were already up I just wanted to double check). right when I pulled up on the switch the car shut off. I turn the key and there is no sign of any electricity going to the car. It's like the car isn't acknowledging I am turning the key. I know the battery isn't drained because of the hazards and the clock still works. But when I turn the key the dash lights, windows, A/C won't turn on and the car won't crank. I am wondering what the problem is and why it shut off when the windows were tried to roll up when already rolled up. I am thinking there is a connection from the battery to the ignition switch that is not working but I am not sure. From my understanding there is an ignition relay that is between the battery and the ignition switch. I have checked the relay and it still works. I do have an external wire going straight from the battery to the ignition relay to pin 30. because there was no power going to that pin in a prior problem.
I am wondering what the problem is and how to fix it.
Aug 1, 2023 at 11:11 PM
I attached the power window wiring schematic below for you to see (pics 1 and 2). There really isn't anything I see there that should have caused this to happen. However, when I work backward, I do see the power relay you mentioned. Also, it is responsible for several different things including the windows.
Pic 3 is from the power distribution schematics showing the circuit breaker for the windows and the relay. Pic 4 shows the relay in question. It is located in the relay box under the dash on the driver's side. Check that relay.
Let me know what you find.
See pics below.
Aug 2, 2023 at 8:24 PM
