Will not shift to high gear
1993 GMC S15
176,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
REDBONE
  • 105 POSTS
Changed fluid and filter in the transmission. After i finished i took the vehicle for a test drive and the vehicle wont shift in high gear.I tried to shift it manually and still wouldn't shift to drive.I get to 35 mph and the vehicle does not shift.
Oct 21, 2019 at 2:27 PM
Good evening,
Did you have this issue prior to the fluid change?
https://www.2carpros.com/articles/automatic-transmission-problems
Oct 21, 2019 at 5:12 PM
REDBONE
  • 105 POSTS
No problems before fluid and filter change.
Oct 22, 2019 at 1:02 PM
Okay, was there any debris in the pan on the magnet?
Oct 22, 2019 at 2:48 PM
REDBONE
  • 105 POSTS
There was some debris on the magnet and the fluid looked dark brown.
Oct 24, 2019 at 11:32 AM
Not good.
I would replace the fluid several times to get rid of the bad fluid.
Oct 24, 2019 at 11:55 AM
