"The vehicle will start the shift"? What does that mean? If the shift lever can't be moved out of "park", check for proper operation of the brake lights. If they are not working, the fuse is likely blown, often due to a chewed-up trailer wiring harness. You need to press the brake pedal to shift out of "park", thanks to our over-educated politicians, and it's the same circuit that runs the brake lights that runs the shifter interlock.
In your case where the shift lever moves throughout its range, but the transmission doesn't go into gear, the cable going to the transmission is broken or became disconnected, usually AT the transmission. If the cable broke, it's because it frayed at one end. That would have given plenty of warning because it would have become harder and harder to move the shift lever. It's also possible for the cable's outer casing to slip in its anchor, again, usually AT the transmission end. Most commonly the symptom, at least at first, is you have to move the shift lever too far to get the desired gear, and / or the indicator might show the wrong gear. Showing the wrong gear can happen on older vehicles with a mechanical pointer. Yours should have a digital indicator in the instrument cluster. The clue then is it continues to show "park" when you move the shift lever.
Dec 17, 2017 at 12:00 AM
