After shifting the transmission into driver and pressing on the accelerator the engine revs, but the car does not move?
2010 NISSAN MAXIMA
100,000 MILES • 2WD • AUTOMATIC
SHERAHJESSIE JOHNSTON
When I start the car and put it in drive, I can push the accelerator all the way to the floor, and it won't rev up and won't go anywhere.
May 30, 2023 at 10:09 AM
You may have a broken CV axle, or the transmission is bad but i would check the level and condition of the fluid and then run the codes to see what comes up.
You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Here is one for about $99.00 if you need it:
https://amzn.to/3ZixY4v
Here is how to check the fluid and a guide as well:
https://www.2carpros.com/articles/automatic-transmission-problems
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
May 30, 2023 at 7:14 PM
