I suspect the fuel pressure is too high. It was most likely damaged. This requires you to perform a fuel pressure test. I need to know what the pressure is. if you look below, the last thing I added were the diagnostics based on fuel pressure. Perform this test and let me know the results. Note that because of the design on this vehicle, there isn't a traditional type fuel pressure regulator.
________________________________________________________________
DTC P228D
- Fuel Pressure Regulator Control Performance - High Pressure
DTC P0089
- Fuel Pressure Regulator Performance
The P0016 is a cam sensor issue. However, we need to first focus on the fuel pressure.
As far as the cam sensor issue, were you working on the engine and possibly disconnected something?
If less than 345 kPa (50 psi)
Refer to Circuit/System Testing - Fuel Pressure Low.
If greater than 650 kPa (94 psi)
Replace the G12 Fuel Pump.
If between 345-650 kPa (50-94 psi)
4. Verify that the fuel pressure decreases to less than 600 kPa (87 psi) after the fuel pump is turned off.
If greater than 600 kPa (87 psi)
If less than 600 kPa (87 psi)
5. Verify that the fuel pressure does not decrease more than 34 kPa (5 psi) in 1 minute.
If greater than 34 kPa (5 psi)
Refer to Circuit/System Testing - Fuel Pressure Leaks Down.
If less than 34 kPa (5 psi)
6. Relieve the fuel pressure to 69 kPa (10 psi).
7. Verify that the fuel pressure does not decrease more than 14 kPa (2 psi) in 5 min.
If greater than 14 kPa (2 psi)
If less than 14 kPa (2 psi)
8. Engine idling.
9. Verify the scan tool Fuel Pressure Sensor parameter is between 300-400 kPa (43-58 psi).
If less than 300 kPa (43 psi)
If greater than 400 kPa (58 psi)
If between 300-400 kPa (43-58 psi)
10. Verify the scan tool Short Term Fuel Pump Trim and the Long Term Fuel Pump Trim when multiplied together are less than 1.5.
If greater than 1.5
If less than 1.5
11. Verify the scan tool Fuel Pressure Sensor and the Desired Fuel Pressure are within 45 kPa (6.5 psi) at 300 kPa (43.5 psi) request or 60 kPa (8.7 psi) at 400 kPa (58 psi) request of each other while operating the vehicle through varying loads.
If greater than 45 kPa (6.5 psi)/60 kPa (8.7 psi)
Refer to Circuit/System Testing - Fuel Pressure Drops Off.
If less than 45 kPa (6.5 psi)/60 kPa (8.7 psi)
12. If the fuel system components test normal, refer to Symptoms - Engine Controls See: Computers and Control Systems > Symptom Related Diagnostic Procedures > Symptoms - Engine Controls, Fuel Injector Solenoid Coil Test See: Fuel Injector > Component Tests and General Diagnostics > Fuel Injector Solenoid Coil Test, and Fuel Injector Balance Test See: Computers and Control Systems > Component Tests and General Diagnostics > Fuel Injector Balance Test.
Fuel Pressure Low
1. Verify none of the conditions listed below exist:
* Restricted fuel feed pipe
* Inspect the harness connectors and the ground circuits of the fuel pump for poor connections.
If a condition exists
Repair as necessary.
If no conditions exist
Note that based on the codes you provided, low pressure shouldn't be the issue. Perform the test and let me know what you find. I have a feeling you will may need to replace the pump.
Feb 24, 2020 at 8:29 PM
