Hello, I have been following your channel for a while now on YouTube and you have helped me through a lot of problems with my car. Now I have a problem that I cannot for the life of me figure out and I need some advice. I drive the car listed above. My car will start just fine and drive pretty well but once it gets warmed up, driving for like ten or fifteen minutes, the engine shuts off when I stop or when I take my foot off the gas when it tries to idle. It will start back up but I can tell it does not want to. I do have a misfire problem that I have not been able to find a fix for, but I have had that problem for about a year now and never affected my idle. everything on the car is all stock/factory. the only major thing i have done was change the head gaskets when I got it a year ago along with all the appropriate gaskets and bolts. so far i have tried cleaning the throttle body with throttle body cleaner, I cleaned the MAF sensor with MAF cleaner. I put a new battery post on my positive because it was corroded, and I put fuel system cleaner in the tank. None of that has worked. if you have any suggestions they would be greatly appreciated.
Your fan,
Travone Evans
Your fan,
Travone Evans
Jan 31, 2018 at 3:13 AM
