Drove the truck in march approximately ten miles, ran like always perfect. Everything works. Parked at a store, took about an hour or so, came back out started the truck and it shut off. Restarted it again and it would not idle and ran very rough. I had to use the both feet to get it home. One on the gas and the other on the brake, at stops I had to put it in neutral, still running terrible. No check engine light. Black smoke out the tailpipe. After I got it home I shut it off. Open the hood nothing out of place. Scanned it, no fault codes at all. Performed KOEO. No codes nothing. Tried KOER and the scanned timed out. No KOER. But while I was keeping it running raw fuel was coming out of the exhaust tailpipe and black smoke. All you smelled was raw gas bad. Fuel pressure 60 psi, compression test all six cylinders 170 to 175 psi. It is a space vehicle so it does not get driving that much. So I closed the hood and let it sit. Well I need it now and nothing changed.its had lots of parts put on it, and changed nothing. The plugs are soaked with fuel all six. And the converters feel like there red hot in just minutes of running. Any advice would be great. Thank you.
Sep 19, 2018 at 10:43 AM
