Okay, so, I own the truck listed above 1500 SLT. All of a sudden, the reverse quit working on me it worked fine the time before I was in it, and I have noticed any slipping of any gears of any kind as of late we either. Would there be another reason the reverse would go out besides the whole transmission going to hell? Any other information would be helpful I did also check the transmission fluid which is ATF + 4 and it would read full when it is cold but when I did it in parked in neutral with the truck running it was dry on the stick, I have checked it twice and I've had the same exact result. Full when it is cold and dry when it is hot. Again, any information would be helpful. thank you
Nov 7, 2023 at 5:37 AM
