Transmission not shifting into gear properly
2009 VOLKSWAGEN TRANSPORTER
89,000 MILES • 2.5L • 2WD • MANUAL
RAY ROBINSON2
Cannot get into first gear, makes horrific noise. then can for few seconds, same sound in reverse, no warning lights are on. thanks
Dec 25, 2020 at 12:32 PM
It sounds like the clutch isn't releasing from the engine. First, is it possible for you to record the sound it's making so I can hear it?
Next, this vehicle isn't offered in the US, but there should be a clutch fluid reservoir under the hood. Locate it and see if it is low or empty. On some of these vehicles, there will be a supply hose straight from the brake master cylinder, so make sure it isn't low if that is the case.
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Let me know what you find.
Dec 25, 2020 at 5:51 PM
