Transmission will not go into drive
2000 BUICK LESABRE
197,000 MILES • 2WD • AUTOMATIC
LJ MERRITT
I can only shift into reverse. I just idle when I go into any drive position but reverse works fine.
Feb 14, 2019 at 5:31 PM
Good morning,
If you have a good reverse and no forward gears, then it sounds like you have an internal failure inside the transmission. This will require removal and inspection for the failure.
https://www.2carpros.com/articles/automatic-transmission-problems
Feb 15, 2019 at 4:46 AM
