I can only shift into reverse. I just idle when I go into any drive position but reverse works fine.
Feb 14, 2019 at 5:31 PM
CERTIFIED EXPERT
Good morning,
If you have a good reverse and no forward gears, then it sounds like you have an internal failure inside the transmission. This will require removal and inspection for the failure.
