Will not go into drive
1972 FORD E-SERIES VAN
135,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
RYAN FLEURY
If I do try to put it In drive it simply will not go. But it will go into reverse.
Before it went out it was slipping and slow.
Jan 27, 2017 at 5:24 PM
CARADIODOC
  • 34,306 POSTS
The most likely cause is low fluid level. Any abnormal slippage will seriously accelerate the clutch plate wear. That alone can result in a failure to more. Debris breaking off the fiber plates can also tear up the rubber lip seals in the clutch packs. Reverse is usually the last gear to go because the line pressure is much higher in reverse, and that can be what is needed to keep the clutch from slipping.
Jan 27, 2017 at 5:31 PM
