No crank no start issue
2014 BMW 535I
134,000 MILES • 6 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
I know the battery is bad, measures 6v and with the battery load test it shows weak then with weak it shows bad, but even with a jumper box i just hear a click. But the thing is, when it tries to or when it clicks everything in dash goes blank as if there is no power or battery, even lights go off. I am going to put another battery tomorrow, but would a weak battery make it go blank when trying to start?
Jun 7, 2022 at 4:46 PM
If you still have the jumper connected, you should still have power. However, what you described sounds like a faulty connection.
Most commonly, a loose battery terminal will cause what you described. When you turn the key to run, it has power. However, when you turn the key to start, the heavy draw from the starter causes it to lose connection temporarily.
Take a look through this link and let me know your thoughts:
Please note that in most cases the problem is with the battery terminals. However, it can be on the opposite ends of the battery cables where they attach.
Jun 7, 2022 at 9:21 PM
BHAMDOC1973
  • 2,008 POSTS
Put a new battery, same thing won't start or turn over, but dash won't dim. It's like it's trying to turn it over.
Jun 8, 2022 at 7:52 PM
If the lights aren't dimming at all when you try to start it, it sounds like the starter simply isn't getting power. However, I need to confirm something. You indicate the lights don't dim but also mentioned it's like it is trying to turn over. Please explain. Do you hear a click or anything when turning the key to the start position?
Let me know. If you could record what is happening and upload it for me, it may be helpful.
Jun 9, 2022 at 8:04 PM
BHAMDOC1973
  • 2,008 POSTS
This is a push button, there is a click sound. I will see if i can record it, sounds like a weak starter that is trying but it isn't strong enough.
Jun 9, 2022 at 8:08 PM
Does the click come from the starter motor? Do this. At the starter, there will be a heavy gauge red wire that should have 12v at all times. First, confirm that is the case.
If it does, have a helper try to start the vehicle. When the start button is pressed, you should then have 12v to the smaller gauge white wire.
If you have both, the starter is likely bad. Try this and let me know what you find.
I attached the starter schematic for your reference. Additionally, here is a link you may find helpful:
See pic below.
Jun 9, 2022 at 8:58 PM
BHAMDOC1973
  • 2,008 POSTS
I removed the starter, and I can move the wheel out by hand, tested it on bench and it works.
I tested it on the car while it's out (not connected to the flywheel) and it spins, power on wire and solenoid. I tried to turn the flywheel, but I have very little space and I'm not sure if I have enough leverage, it is also in park, not sure if the flywheel can be moved while in park. You cannot put these cars in neutral unless they are running. So, not sure, I sent my son to test the starter, maybe it is weak and works on bench but under load it doesn't.
Jun 11, 2022 at 3:31 PM
BHAMDOC1973
  • 2,008 POSTS
Sent my son to have tested at advance, they said it failed something about the rod. Is my test different than their test?
Jun 11, 2022 at 4:07 PM
BHAMDOC1973
  • 2,008 POSTS
Just called them, they said it's supposed to push out and turn but it was only turning and not pushing out. Strange. If it wasn't then how come i didn't hear it spin while it was on the car and it only clicked.
Jun 11, 2022 at 4:18 PM
I didn't realize it was spinning. I thought there was no response when you tried starting it. As far as the flywheel, it will turn when it's in park.
If the starter is spinning and the drive gear doesn't kick out, the Bendix is bad and prevents it from engaging with the flywheel. However, you mentioned it only clicked, so that threw me.
Have you tried a new starter yet?
Jun 11, 2022 at 7:25 PM
BHAMDOC1973
  • 2,008 POSTS
There was no spinning when i was trying to crank, it only spins when i remove it. i ordered another one.
Jun 11, 2022 at 7:31 PM
Were you able to check for power at the white wire on the starter to determine if it was getting what it needed to engage? I ask because if you had power, it should have at least spun.
Jun 11, 2022 at 8:11 PM
BHAMDOC1973
  • 2,008 POSTS
Yes, the wire is getting power when it starts, otherwise the starter won't spin. I let the starter be connected to the wires but not installed in its place and it spun, but am not sure if this is the spun it should have had, advance said it didn't go out.
Jun 11, 2022 at 8:17 PM
Yes, the drive gear should kick out, so it contacts the flywheel. If it doesn't, you are better off just replacing the starter. Years ago, we would rebuild them, but the cost of labor now would likely cause this to be a more expensive route.
Regardless, let me know if the new starter takes care of the issue.
Jun 11, 2022 at 9:23 PM
BHAMDOC1973
  • 2,008 POSTS
Put a new starter, and just like the original one it started to get hot only from two tries, it sounded better like it was trying to move the engine, but smoke came from it from heating especially the short wire between the starter and solenoid, extremely hot. I also had a jumper and it smoked from where i was attaching the ground cable, so i stopped.
Jun 14, 2022 at 3:56 PM
Are you sure the engine isn't locked? If you place a socket and a breaker bar on the crankshaft pulley bolt, are you able to turn the engine? If the starter can't turn the engine and it's smoking, that is what it sounds like.
Jun 14, 2022 at 9:24 PM
BHAMDOC1973
  • 2,008 POSTS
It is extremely difficult to get to the bolt where it is, these cars will not go into neutral without the engine running.
Jun 15, 2022 at 5:54 AM
Something is preventing the starter from turning the engine. Are you able to get to anything that will turn the engine?
Also, if you go to the center bolt on the crankshaft pulley, you have to be careful not to loosen it. If it becomes loose, the timing will require adjustment.
Jun 15, 2022 at 9:29 PM
BHAMDOC1973
  • 2,008 POSTS
I can't get to the bolt its tight and car is parked outside on a small incline and cannot be put in neutral to be moved. Why would loosening the bolt requires timing adjustments?
Jun 16, 2022 at 5:34 AM
When you loosen the center bolt, it changes the crankshaft position sensor angle. Take a look at the pic below.
As far as the shift lock is concerned, you can manually bypass it. The remaining pics below are the directions to release the shifter.
Let me know if this helps.
See pics below.
Jun 16, 2022 at 9:14 PM
BHAMDOC1973
  • 2,008 POSTS
I knew about this release mechanism, but this car does not have it. That was the first thing i checked. No tool, and these ashtrays are different, they don't come out. Tow truck also knew about it and couldn't find any other way to put it in neutral.
Jun 17, 2022 at 6:11 AM
Unfortunately, that is the only way I am aware of. You know what? Let me know the production date. It may be an early or late model and has a different design.
The production date should be on the driver's side door.
Jun 17, 2022 at 7:10 PM
BHAMDOC1973
  • 2,008 POSTS
10/13.
Jun 17, 2022 at 7:13 PM
That is an early production, but it shows the same procedure. I also check 2015 and it's the same.
I dug through my manual and found a way to do it from under the vehicle. Take a look at the directions below. Please make sure the wheels are blocked and the parking brake is applied. I know it's on a hill.
Take a look and let me know.
See pics below.
Jun 17, 2022 at 7:40 PM
BHAMDOC1973
  • 2,008 POSTS
I won't be able to do it from under, i know about that method, car is on a slope. The cup holders on this one is part of the whole console. I had several others with removable cup holders but not this one.
Jun 17, 2022 at 7:44 PM
I have no idea why the inside release isn't on your vehicle. Is there something different as far as the model? The only other way I know of is from under the vehicle.
I wish I could be of more help. Let me know.
Jun 18, 2022 at 9:56 PM
BHAMDOC1973
  • 2,008 POSTS
A guy came to buy it as is. Went to show him what happens when you try to start it and the damn thing started but rough so he said leave it, it could be a bent valve, so sold it like it that.
Jul 22, 2022 at 6:06 PM
That is what would have happened to me if I sold it. Regardless, I thank you for the update. Please feel free to come back anytime in the future.
Jul 22, 2022 at 8:01 PM
