Engine will not crank
2001 BMW 525I
170,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
Slight overheating problem someone took apart to check compression after that it wouldn't crank, then oil poured out.
Jan 31, 2022 at 5:19 PM
Where did the oil leak from? Also, when you say it won't crank, do you mean the starter won't turn the engine, or do you mean it does turn but doesn't start?
Let me know as much as you can so I can better help you. I just need a little more information.
Let me know. Also, feel free to let me know if you have questions.
Jan 31, 2022 at 8:06 PM
