After replacing the plugs and headlights the engine will not crank
1991 CHEVROLET 1500
100,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
MICHAEL NEEDS HELP
  • 23 POSTS
Changed plugs and headlights now it won't crank.
Feb 23, 2022 at 6:24 AM
SQM
  • 6,383 POSTS
Can you tell me what it exactly doing?
Does it click or make any noise when you try to start it?
Are you getting any lights illuminated on the dash?
Just so we cover the basics, have you tried to jump start it? It is possible to have a discharged battery and that could be the cause of no start.
https://www.2carpros.com/articles/how-to-jump-start-car-battery-using-jumper-cables
If you are able to jump start it and it runs normal, then it is likely just a bad battery.
Please let me know what you have been experiencing.
Thank you.
Feb 23, 2022 at 9:03 AM
MICHAEL NEEDS HELP
  • 23 POSTS
Brand new battery. Dash lights and everything works.
Feb 23, 2022 at 9:44 AM
SQM
  • 6,383 POSTS
Just watched the video. The engine is cranking over but not starting.
This could be due to not getting any spark or fuel.
You will need to check to see if there is spark to the plugs. Also, can you hear the fuel pump when the key is in the on position?
Take a look at this guide, it covers the typical crank / no start issues:
https://www.2carpros.com/articles/car-not-running-advanced
One thing you can try is to spray starting fluid into the intake. If it is a fuel issue, the engine will start and run for a little bit.
Feb 23, 2022 at 9:55 AM
MICHAEL NEEDS HELP
  • 23 POSTS
Fuel pump is working. Got spark. Tried spraying it with starting fluid and got nothing.
Feb 23, 2022 at 10:03 AM
SQM
  • 6,383 POSTS
If the spark is not strong it won't start.
I would recommend you go through the guide that I sent the link earlier. It covers all the basics. Let me know what you find.
Feb 23, 2022 at 2:59 PM
MICHAEL NEEDS HELP
  • 23 POSTS
After yesterday I found these two things unplugged. can you tell me where they go?
Feb 24, 2022 at 7:51 AM
SQM
  • 6,383 POSTS
On the first picture I see that it is by the distributor, can you tell me how many wires on that plug? Also, maybe another picture from a different angle would help.
You can also check to see if there is power to the connector with the key to the on position. This could tell us if this is for the ignition system.
Feb 24, 2022 at 7:57 AM
MICHAEL NEEDS HELP
  • 23 POSTS
Here's more pics of the plug. Could it go to the fuel pump?
Feb 24, 2022 at 8:10 AM
MICHAEL NEEDS HELP
  • 23 POSTS
There is one wire and it's hard to tell if it's blue or purple or what because I am color blind.
Feb 24, 2022 at 9:11 AM
MICHAEL NEEDS HELP
  • 23 POSTS
Also where does this go?
Feb 24, 2022 at 10:06 AM
SQM
  • 6,383 POSTS
I am having difficulty finding the harness that those plugs belongs to.
When you turn the key on, is there power to those connectors?
Check the coil pack and make sure the connectors are secure.
Feb 25, 2022 at 3:13 PM
MICHAEL NEEDS HELP
  • 23 POSTS
I have narrowed it down to either a bad fuel pump relay or a bad ignition relay or a bad pump. I have replaced the filter, but it won't crank, it's still trying but not quite. Also, I had to take brand new battery back, as it drained practically in an hour, without me doing anything.
Feb 26, 2022 at 10:41 PM
SQM
  • 6,383 POSTS
If the pump is turning on, then it is not the relay. It could be a weak pump that is not providing adequate pressure. Or some sort of restriction in the line, like a dirty fuel filter of a clog in the line.
If the pump is turning on, then testing the fuel pressure can help you determine if the pump is weak or has issues in line or a bad fuel pressure regulator.
This engine should have at least 62 PSI fuel pressure with the key on and engine off.
Feb 26, 2022 at 11:18 PM
MICHAEL NEEDS HELP
  • 23 POSTS
After a day of rest, I'm back at it, this time I have replaced the plugs, fuel relay switch, headlights and still no crank. so, I went chasing a loosen ground wire. Well low and behold I found something, but I don't know what it is, I made a video and took several frames for you, this is shot on the firewall looking forward. What is the black and is it disconnected? Also is this ground wire supposed to have something else hooked to it I know it's dirty.
Mar 1, 2022 at 7:29 PM
SQM
  • 6,383 POSTS
It is difficult to figure from the picture. But the black piece looks like part of some sort of connector or seal.
The ground wire looks to be normal. You do want to clean around it and possibly remove the bolt and clean the mounting surface for good contact.
Mar 1, 2022 at 10:44 PM
MICHAEL NEEDS HELP
  • 23 POSTS
After much looking, I am down to the starter or the fuel pump, mind you all this started with a head light bulb replacement. I made a video of the starter; sorry it was the best I could do. I'm lost at what I'm looking at or for.
Mar 2, 2022 at 9:15 PM
SQM
  • 6,383 POSTS
From one of the earlier videos you uploaded, the engine is cranking over. Since it is cranking over the issue probably not the starter. As if the starter was bad, you will get a clicking noise and that will be all with not cranking over.
Did you get a chance to check for fuel? Even if the pump is turning on, it is possible to have some sort of clog in the fuel line or have a bad fuel pressure regulator.
As you mentioned you are getting a good spark, then the only item left is fuel.
It is strange that you are having all these issues for no apparent reason. As the light but change does not have anything to do with what you are dealing with.
Mar 3, 2022 at 11:07 PM
