Will not start
1998 FORD FALCON
210 MILES • 4.1L • 6 CYL • 2WD • MANUAL
TINA DUGGAN
  • 5 POSTS
Hi, I brought this xh ute and drove it home it drove like a new car I started it without a problem a couple of times then one morning tried starting it and it wound slow like the battery was going flat and then the tension-er pulley let go. so I brought another pulley and stater motor and replaced them now the car is still winding slow and will not fire and both terminals are getting super hot. Please help.
Jan 22, 2018 at 8:59 PM
It sounds like your battery is having a problem. to confirm the issue can you follow this guide to load test the battery?
Jan 24, 2018 at 12:58 PM
TINA DUGGAN
  • 5 POSTS
Hi Ken, I have already tried a brand new battery and have fully charged the battery that is in it. If it was the battery I would have already had it going. I have also looked at all the fuses. I have looked at the smart lock an it is not the problem.
Jan 24, 2018 at 3:51 PM
Sorry you did not say battery in your first post. It sounds like the starter motor has gone out but to be sure we need to test for power at the trigger wire of the starter (small). Here is a guide that will show you how (look toward the bottom):
It has a link on what you will be in for when changing the starter motor out.
Please run some tests and get back to us.
Jan 24, 2018 at 4:13 PM
TINA DUGGAN
  • 5 POSTS
Sorry for not mentioning the battery. I also thought starter motor so I replaced it and still it wound slow. so I bought another starter an put it in. So that is three starters I have put in now. The last starter I put in is winding quicker but it is still not firing and both terminals are super hot when I wind it over.
Jan 24, 2018 at 4:42 PM
The heat can be caused by one of two things either there is a bad connection or the starter motor is working to hard. Can you please shoot a quick video and upload it in your response of the engine cranking over so I can hear it? I will be able to tell quickly whats going on.
Jan 25, 2018 at 10:04 AM
TINA DUGGAN
  • 5 POSTS
Hi I've recorded trying to start it with a filly charged battery
Jan 25, 2018 at 5:28 PM
TINA DUGGAN
  • 5 POSTS
Hi be tried uploading it trying to start bit it gets to almost uploaded then says it can't complete I will try later when I have WiFi sorry
Jan 25, 2018 at 5:29 PM
