Will Not start
1999 SAAB 9-5
177,000 MILES • 3.0L • V6 • AUTOMATIC
SAVAGE VALENTINE
I turn the key it cranks, but it will not start.
May 7, 2016 at 10:23 AM
HMAC300
  • 48,601 POSTS
try resetting the security system or another key if no manual look online for your car on how to do it.
May 7, 2016 at 1:55 PM
JDL
  • 16,098 POSTS
How long since a tune-up? Are there any applicable trouble codes? The basics, if it cranks good but will not start, have a helper crank it while you check for spark at the spark plugs. If spark everywhere, use a gauge and check proper fuel pressure and fuel injector pulse. If you have more than one issue, check the crank sensor. The two most commonly replaced parts on your vehicle for, cranks good but will not start, is the fuel pump and crank sensor. I cannot rule out other issues? Do not replace anything unless your testing points in that direction.
JDL
  • 16,098 POSTS
Hi hmac, did not see you. Everybody have a good day.
May 7, 2016 at 1:56 PM
RENEE L
  • 1,260 POSTS
Thank you JDL for your informative answer.
May 9, 2016 at 11:51 AM
