Engine starter not working?
2007 GMC ENVOY
95,000 MILES • 4WD • AUTOMATIC
DONNESCH
Today Envoy won't start-just makes clicking sound. All electronics appear to work. Altonator and battery replaced one year ago.
Mar 21, 2016 at 12:59 AM
CJ MEDEVAC
  • 11,004 POSTS
This sounds like you have a bad connection or the starter motor had gone bad but to be sure these guides will help us fix it.
https://www.2carpros.com/articles/starter-not-working-repair
and
Mar 21, 2016 at 2:23 AM
ALLENRTASSINARI
I had this problem the guide helped me find the bad starter. I got new one from amazon and BAM! all fixed.
Oct 28, 2020 at 1:11 PM
HERMIT
  • 14 POSTS
New battery, starter, MAP sensor, ignition switch. lights up dash but will not start.
Oct 28, 2020 at 1:12 PM (Merged)
Does the starter engage and turn the engine? Have you checked fuses as well as the starter relay?
If it does engage and the engine doesn't start, take a look through this link:
If it doesn't crank or engage the starter, take a look through this link that explains how to test a starter. I realize the starter is new, but I need to confirm if power is getting to it.
If the starter does not engage follow the next steps.
I attached two pics below. I need you to confirm the fuses indicated are good and there is power to them. Also, if there is another relay in the box with the same part number, switch it with the starter relay.
Note: I would also like you to confirm that the gear selection light indicates park. Additionally, see if it will start in neutral.
________________________________________________
Here are a few links you may find helpful when testing:
https://www.2carpros.com/articles/how-a-car-fuse-works
HERMIT
  • 14 POSTS
Hello,thanks for the info.I had a mobile mechanic come to my house.He is coming back.he got it started but said the wire on the starter has a short which is causing random lights,locks and gauges inoperable. will let you know how I make out.Times are tough,so thanks for your help.
I completely understand. If you get the chance, let me know what is found.
Take care and let me know if I can help.
HERMIT
  • 14 POSTS
My daughter had a mechanic at a shop to come and check it out.paid him sixty bucks and all he did was to get it started.he didn't return.not starting again.gas gauge now shows full(I wish) and radio not working.security light stays on after I try to start after all gauge lights go out.we haven't used the car remotes in a few years and I can't locate them,so back at it again.
If the security light is staying on, I need you to try something. Turn the key to the run position (engine off) and wait approximately 10 minutes. See if the light goes off. If it does, see if it will start.
If that does nothing, let me know if the starter is still engaging and turning the engine normally.
Let me know what happens.
TIGERMOM30
Went and got an oil change ran great. Parked it over night, went to start it in the morning and absolutely nothing. No power inside or out, no crank no start. We have changed the starter, starter solenoid, ignition switch, numeral safety switch, starter relay, negative cable, also had the battery and alternator checked all good. Please help at a loss now.
Good evening.
Does it run at this time?
https://www.2carpros.com/articles/car-battery-dead-overnight
HERMIT
  • 14 POSTS
Hi Joe,it started! the security light stayed on.i shut it off and waited for the lights to go off from my door.they did and tail lights flashed twice.
TIGERMOM30
No, still no power at all.
HERMIT
  • 14 POSTS
Update: second attempt was a no start with a nice light show in and out.security light on.waited a bit for another try.no light show this time but battery and security and battery light on.closed the door while I'm sitting in it and the battery light goes off and security light stays on.wait a bit to try again and after a few attempts it starts but all cluster is lit up.turn it off and the battery and security light stays on.each shut off after a few minutes. 9k I'm going to stop for the night.really confused.
Okay, do you have a voltmeter to check the battery voltage?
If it is starting after waiting the 10 minutes, it is a security issue. Do you have a spare key you could try? If not, and I hate to say this, you need to have it scanned. It will require an upper level scanner. A basic powertrain scanner won't read the codes.
Let me know if that is what is happening. If you could, let me know what you meant by everything on the dash lit up.
TIGERMOM30
Yes, battery is good.
HERMIT
  • 14 POSTS
Good afternoon! Called another mobile mechanic and he's going to look at it.Off the top of his head,he said it might be an immobilizer lockout.Ill let you know how I make out.
What is the voltage?
That is what I suspect as well. If it starts after sitting for the 10 minutes, the security (immobilizer) is being bypassed.
Let me know. I'm really interested in knowing if that is it.
LARRYNELSON
2006 GMC Envoy
newbattery just clicks
Possibilities here could be the starter motor, starter relay, transmission range switch and ignition switch assuming the battery and connections are good.
HERMIT
  • 14 POSTS
Mobile mechanic was a no show,left me hanging!I'll find another and let you know.thanks!
Wow. One would think people could be more responsible. Things have changed over the years. There was a time when one's character meant something. If you told someone you would do something, you made sure you were there to do it. Not anymore.
HERMIT
  • 14 POSTS
Found another mobile mechanic 3 days ago.i was at work.he got it to start.he left.my wife got in it to pick me up at work an hour later and another no start.he said he would come back.he didn't and won't respond,so another person ripped me off.still no transportation and I will lose my job over this and shady people who claim to be certified mechanics.
By any chance, did this one leave a receipt with what was done to make it start? I have to be honest, you may be better off having it towed to a reliable shop at this point because I truly feel, based on your description, it is something with the immobilizer (anti theft). If I am correct, it will require a scanner to relearn the system. If you have a spare key, try it to see if it makes a difference.
HERMIT
  • 14 POSTS
Hi,I'll ask my wife if he left one.he has blocked her number.i called another myself and stood there with him.He informed me that I am indeed locked out and will need to call a mobile locksmith to the house for a new key.what a nightmare!
I had a feeling. Chances are to get it running, they did what I originally suggested wait 10 minutes and see if the light goes out. Do you have a spare key to try or have you already done that?
HERMIT
  • 14 POSTS
Spare key will not work either.first time using a mobile mechanic and cost me money I didn't have.lost everything, starting over so looking where I can save a little.you have been extremely helpful and I will let you know how I make out.Thank you!
You are very welcome. I have been in that same place many times. Hang in there. It always works out. I will watch for your reply.
HERMIT
  • 14 POSTS
Hello, Envoy is toast at the dealership and they said it needs a wiring harness, CPU,and other things to get a scan.over two grand and they are not sure if it will fix it.heck of a way to start the new year.Thanks for all your help!!!
Wow! Was the wiring damaged by any of the people that came to you to repair it?
HERMIT
  • 14 POSTS
It was not.Not a clue what happened.dealership said it's just a big mess.What a year! Bad luck all year right until the end.2020 will be better!
It sounds like someone got into things they shouldn't have. I hope things get better for you. Let me know how things work out with the vehicle, and let me know if you have questions or need anything.
Take care of yourself.
HERMIT
  • 14 POSTS
Thank you! Lesson learned about mobile mechanics.Research them if you have to use one. I am deaf in one ear and don't do well on phones,so I was dependent on my wife and daughter (know everything,lol) and between all of them this is where it got me.not blaming but who knows.Take care and thanks again!
OMG!!! You made me laugh. My wife is deaf in one ear, but she is the same as what you deal with. I'm sorry to hear you have such a problem. I often feel bad for her because I know she struggles.
Please feel free to come back any time you have a problem. I hope the new year brings you much better luck.
Take care and hope to hear from you in the future. (not saying I hope you have car problems.)LOL
HERMIT
  • 14 POSTS
It's been an experience.Thanks for getting me info.Rebuilding everything from scratch.My daughter said she would buy me a used car soon.I am going to get mine back and use it as a driveway ornament until I do something with it.I could have an engine installed for half the cost of the dealership fix!Take care and thanks again for all your help.
You are very welcome. Hope to hear from you again in the future if we are needed.
