Engine noise?
2013 VOLVO XC90
143,000 MILES • 6 CYL • 4WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
This is a 3.2l can you tell what this could be? The pulleys on these engines are on the right side of the engine.
Oct 1, 2025 at 10:08 AM
CANNON1349
  • 861 POSTS
Hello, it could be something with the pulleys or the bearings in that system, best to check with the serpentine belt off and spin each pulley by hand. Have you had the timing belt changed? If worn out the components can make noise and should be replaced as a set.
Hope this helps,
William
Oct 1, 2025 at 4:49 PM
BHAMDOC1973
  • 2,008 POSTS
this has a chain, will check and see
Oct 1, 2025 at 4:54 PM
CANNON1349
  • 861 POSTS
If this does indeed have a chain I would put a screwdriver to the top of the cover there and listen if the noise is clearly audible. VVT Actuators are known to be noisy as well as the timing tensioners giving up, leaving enough slack for the chain to move around.
William
Oct 1, 2025 at 4:56 PM
BHAMDOC1973
  • 2,008 POSTS
will do thanks
Oct 1, 2025 at 4:58 PM
CANNON1349 is one of our best, please let us know how it goes ;)
Oct 7, 2025 at 10:20 AM
