The brake and signal lights work from the same power supply. I need you to first check to see if there is power to the light socket. All you need to do is take a test light or multi meter to check.
If you look at the attached pic, you will see there is a brown wire that supplies the power. Check that wire in the socket that for power.
I need to know something as well. When you remove the light assembly from the truck, is the rear of the light housing a printed circuit board?
Here are a few links you may find helpful when testing:
______________________________________
Apr 14, 2020 at 4:16 PM
