wiring harness from air conditioner amplifier
1995 TOYOTA COROLLA
160,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
BONZKIE28
  • 13 POSTS
color coding or wiring diagramming of the sub wiring harness from air conditioner amp to the the thermistor and main connector of the car? The old one was removed and not replace by a knew one. Thanks
Apr 26, 2016 at 2:21 AM
HMAC300
  • 48,601 POSTS
yellow and white and light green go to switch.
Apr 26, 2016 at 6:00 AM
BONZKIE28
  • 13 POSTS
thanks for the diagram,1.6L and 1.8L have the same diagram?
Apr 26, 2016 at 6:20 PM
BONZKIE28
  • 13 POSTS
yellow ,white and light green to the switch? do you mean ignition switch sir?
Apr 26, 2016 at 6:25 PM
BONZKIE28
  • 13 POSTS
thanks sir i will try to find the wiring's on the and car, i will try to fix it.,
Apr 26, 2016 at 7:55 PM
BONZKIE28
  • 13 POSTS
that was only lifted to may car sir the primary socket terminal,of the ac amp.,the sub wiring harness was messing.
Apr 26, 2016 at 7:57 PM
HMAC300
  • 48,601 POSTS
the harness pic I sent is for a 1.6 what you asked for or listed. here is switch
Apr 27, 2016 at 7:16 AM
BONZKIE28
  • 13 POSTS
Thanks sir,
Apr 27, 2016 at 4:13 PM
Please let us know how ti goes, we are here to help
Apr 28, 2016 at 8:02 AM
BONZKIE28
  • 13 POSTS
ok sir thakz, i will update you, im just waiting the sub wiring harness to arrived.
Apr 28, 2016 at 6:11 PM
BONZKIE28
  • 13 POSTS
Sir good day.has been a long time to log in.,sir was already put a wiring harness ang ac amp.but when i turn on an ac switch the ac compresor didnot kick on.i been follow the wiring diagram that you given to me.the idle up is finction already .but new problem is the ac compresor not kick on.sir aside from low and hi switch ,they have another switch ?
May 11, 2016 at 10:17 PM
BONZKIE28
  • 13 POSTS
Sir can i ask the actual amage of the ac switch?thanks
May 11, 2016 at 10:19 PM
It should be 5 to 10 amp
May 12, 2016 at 7:26 AM
BONZKIE28
  • 13 POSTS
good day sir,i already put an ac amp. to my car.the idle of my car has been raise up every time i on the ac,,thanks for the diagram that you send to me,its help me..by the way sir i will ask you again ,what is the purpose of the coolant that flow inside the idle air control valve housing?
May 29, 2016 at 9:26 PM
HMAC300
  • 48,601 POSTS
if you didn't have the coolant in your throttle body not the idle air control as you car warmed up it would spit and cough etc
May 30, 2016 at 5:47 AM
MIKI#
  • 10 POSTS
Hi HMAC300,
Could you kindly share the full size complete diagram of the entire A/C system that you shared on your first reply above?
Thank you.
Jun 10, 2020 at 5:37 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Unfortunately you've attached yourself to a years old question.Please start your question including all your vehicle information.Here is the link:
Hope this helps and thanks for using 2CarPros
Jun 10, 2020 at 7:49 AM
