Cluster not lighting up
2000 DODGE DURANGO
186,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
SPRMARIO9
My instrument panel displays odometer and warning lights but the gauges are not lit up even though they are operational. I've tried self-diagnoses, disconnecting the negative terminal for half an hour, and replacing the instrument cluster with a replacement and it functions the same. Fuse tests properly and I'm all out of ideas other than to follow the wires looking for issues. hope you can help!?
Nov 24, 2019 at 10:49 PM
JONNYB1963
  • 263 POSTS
Good morning,
From what i read here, it looks to me like its a loose ground wire. I would start looking at the wires under the dash. You will be looking for wires that end in a ring terminal that are bolted to metal structures under the dash (body sheet metal or tube structures). This is actually a pretty common issue on older cars. Sometimes the bolt shakes loose and it loses connection, other times the wires break away from the ring terminal and you have to crimp a new terminal to the wire(s).
Jon
Nov 26, 2019 at 8:50 AM
SPRMARIO9
Thanks for your response and suggestion, I'm looking into it and will let you know how it goes.
Nov 27, 2019 at 10:46 AM
JONNYB1963 is one of our best. Please let us know what you find. We are interested to see what it is.
Dec 1, 2019 at 2:47 PM
