Wiring for Heated/Ventilated seats
2012 LINCOLN MKS
80,000 MILES
STHOMPS30
Shot in the dark - but I have a 2002 4runner I'm attempting to do a seat swap in.
I was able to wire up some seats from a Volvo XC70 but they were too tall and wide.
I found the MKS heated/ventilated seats with the power lumbar and pulled them from a salvage yard.
I'd seen some wire diagram posts for MKZ/MKX - is it same for MKS and any thoughts on how to wire up to a set of switches for the Heat/Ventilation and get it powered up in a different vehicle?
many thanks!
Oct 20, 2020 at 12:13 PM
I have to be honest, I'm not sure where I would start with this one. I have attached wiring schematics (MKS) for the seats. Pics 1 and 2 are for the driver's seat and climate-controlled seats. Pics 3 and 4 are specific to the passenger's side seat power options.
Pics 1 and 2 for the climate-controlled seats
Pic 3 and 4 are for the passenger side seat controls
____________________
Take a look through them and see if this helps. You didn't mention the rear seat heaters, so let me know if you need them as well.
Oct 20, 2020 at 4:35 PM
STHOMPS30
Joe,
Many thanks. That confirms that MKS wiring is at least slightly different from MKX (Only schematic i could find via Google...)
Any chance you could:
A) Post driver side seat motor diagram so I can confirm power wire colors?
B) Know know how to decode or where I could find full descriptions for climate control schematic? (The abbrev on left)
Almost picturing wiring work around.
Motors just splice into power/ground & done (was a 2nd wire to power on XCs bunearly that simple)
Climate control - i see +/- for both. I'm almost what looks to be hot/cool and high/low, just needing to picture how to replicate. MKS main dash circuit with 2 pair switch/relay per side...
Again many thanks for the diagrams posted already!
Oct 20, 2020 at 8:20 PM
I think you are referring (+ / -) which indicate power or ground. As for the driver's seat, the only thing I was able to find was a pin-out of the connectors for each motor. I attached them. Also, the last pic shows the locations of specific components on and in the seat.
I hope this helps.
Oct 21, 2020 at 8:07 PM
