Wiring diagram for accelerator pedal position sensor connector needed?
2013 GMC TERRAIN
164,000 MILES • 2.4L • 6 CYL • 2WD • AUTOMATIC
ANNETTE 72
Wires on my car have been cut to the accelerator pedal position sensor and had to get a new connector. I don't know what the 5 wires actually are so how can I connect the connector without knowing the 6-pin wiring diagram.
Aug 3, 2023 at 7:46 AM
Here is the connector view and the wiring diagrams for the accelerator pedal position sensor. This guide can help you with the test of the connections:
Aug 3, 2023 at 2:05 PM
anything?
May 6, 2024 at 12:03 PM
KINGARTHUR
Hi Ken! I'm not Annette, but I was able to confirm the 5V reference voltage isn't being supplied to circuit 1274. Thank you very much for the information above!
I'm going to try to find where that circuit begins so I can isolate where on the wire I have damage. From what I saw, the unwrapped portion of cable seems to be in good condition between the engine bay connector and the pedal connector, but I'd like to verify continuity with my multimeter. Then it's from there back to whatever supply it gets.
Oct 5, 2025 at 4:20 PM
Hello King!
Here is the wiring daigrams for the accelerator position sensor and a guide to help you with the testing.
Sorry for the repeat, the site had a problem but it is fixed now. Check out the images (below). Let us know what you find.
Oct 7, 2025 at 11:01 AM
