ABS and traction control lights are on?
2010 MAZDA 6
120,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
XXBRITNEEXX007
I am having an electrical issue and not sure if it's battery cable, connection, or just bad battery. I have a voltage meter and want to test the battery and sensors, etc. Also, my ABS light and traction control light are on. Any diagrams or information is greatly appreciated.
Dec 26, 2023 at 7:21 PM
Sorry, we only handle one problem per thread, please post your question about the battery here, you must be logged in.
We will handle the ABS and traction control lights on this thread. Chances are the one of the front or rear ABS wheel speed sensors has gone bad or the wiring gets torn apart due to an obstruction on the road. You can do an inspection of the sensor wiring and if okay let's run the codes to see which ones are stored. That way we can fix the problem without throwing needless parts at it. Please go over this guide/video to help us and I have left the location and how to change the sensors out in the images below in case a code comes up for it.
https://www.2carpros.com/articles/anti-lock-system-testing-and-repair-abs
Check out the images (below). Let us know how it goes.
Dec 27, 2023 at 1:22 PM
XXBRITNEEXX007
My codes are p0335 and p0134.
Dec 27, 2023 at 1:25 PM
These are not ABS codes they have to do with the crankshaft sensor and oxygen sensor not the ABS system. Please start a new question for each of these codes. Did you go over the guide above? You must use a scanner that can read the ABS codes, which is different than a powertrain scanner.
Dec 28, 2023 at 7:52 AM
