Wiring diagram needed
1999 MAZDA 626
235 MILES • 4 CYL • 2WD • AUTOMATIC
JAREDWILKES2
Some one ripped my steering column off. Two wires (yellow and green) sticking out now coming from some plug going back through fire wall. Security is on system is activated I believe. Can these wires cause that? Where do they go?
Jan 27, 2019 at 6:37 AM
STEVE W.
  • 15,113 POSTS
Hello and welcome to 2CarPros. Would it be possible to take a few pictures and load them on this site? There are a few different Yellow and Green wires used, are there any colored stripes on them? That and a few pictures would help narrow down which wiring diagram(s) you would need. There are roughly 25 different ones and many have wires going in that area.
Being the column was damaged there could easily be other issues depending on which wires contacted grounds or powers when they shouldn't. The security system is active because of the damage more than likely, not just the loose wires. Depending on the actual damage you may need a replacement column and security module.
Jan 27, 2019 at 11:17 AM
