Wiring diagram needed for under dash
2005 PONTIAC GRAND PRIX
131,000 MILES • 4.0L • 6 CYL • 2WD
REDNECK0819
  • 8 POSTS
Need a complete wiring diagram from under the dash.
Nov 13, 2020 at 5:21 PM
Good evening,
I attached the diagrams for the under dash cluster for the dashboard.
Is there a particular system that has an issue?
Nov 13, 2020 at 5:29 PM
Unfortunately, the way they break down the wiring diagrams is by system or component. So for example, here is the wiring diagram for the cluster and related components. This means getting you the under dash wiring would be quite a bit so it would be better if you tell us what system you are working on if not the cluster and we can provide that diagram.
Nov 13, 2020 at 5:30 PM
