Code 000406, wiring diagram needed
2010 AUDI R8
134,800 MILES • 5.0L • V10 • 4WD • AUTOMATIC
SEVAG P
  • 405 POSTS
Hi, I have a fault code 000406 related to oil temperature sensor, oil temperature warning appeared, and the indicator is not working. The car has two oil temperature sensors, one under the intake manifold and the second inside oil reservoir which is the sensor also measures the level and the temperature, which sensor is responsible for reading instrument oil temperature indicator? need a wiring diagram to check the wires before replacing the sensor.
Thank you.
Jun 28, 2022 at 10:01 PM
Sorry SEVAG, we have no engine wiring diagrams from Alldata or Mitchell1, if you find any please post them.
Jun 29, 2022 at 5:35 PM
