Wiring Codes
1969 CHEVROLET CORVETTE
DODDLEBUG
Have a 1969 Corvette with a 1973 Steering Column. Need to know the color of the wire coming out of the Steering Column for the horn and also the color of the wire going to the horn relay. Also need to know if the horn button when depressed is a negative or positive contact?
May 8, 2013 at 3:45 PM
ground control. the wire on the end of the turn signal switch harness is the horn wire. stab it with a test light and it should ground the relay.
green wire to the horns
roy
May 8, 2013 at 4:29 PM
