Can I get the wiring diagram for the fuel pump?
1998 MAZDA PROTEGE
220,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
MALINA7
  • 22 POSTS
I need the wiring diagram for the fuel pump to see if the wires are hooked up right because they were cut and rewired.
Mar 13, 2023 at 10:33 PM
STEVE W.
  • 15,113 POSTS
Here are the diagrams for the connector and wiring. The black wire is ground, the black with pink tracs is pump power. The gray wire is the fuel sender signal wire and if it's used the last terminal is a green that grounds the fuel sender, on most that is internal. The pump not working or just wondering if they were reversed?
Mar 14, 2023 at 1:24 AM
MALINA7
  • 22 POSTS
The fuel pump is connected directly to the battery right now, but we don't want to keep it like that. We want to rewire it like it should be.
Mar 14, 2023 at 1:38 AM
STEVE W.
  • 15,113 POSTS
Okay, find the relays power feed to the pump and test it while you can run the car as it is. It wouldn't be good to rewire it to stock only to discover that there is a problem with the power feed and now you are stuck with a non-running car. So be sure the ground is good and that you have battery power on the black with pink wire first and that it turns on and off with the key. Then wire it up.
Mar 14, 2023 at 7:33 AM
MALINA7
  • 22 POSTS
Thank you, I'll let you know how it all goes. What you're saying makes so much sense I think it'll be successful. I'll let you know soon.
Mar 14, 2023 at 8:09 PM
STEVE W. is one of our best! Please let us know what you find.
Mar 16, 2023 at 6:46 PM
