These are the Power Distribution wiring diagrams, diagram 1,2 (top and bottom) and so on. There are 4 pages in total, Fuse 37 is indicated in the first diagram. But inside these fuse boxes there are soldered traces which run power to each fuse and relay, so there is most likely a broke solder trace inside the fuse box if you don't find any corroded connectors on the bottom of the fuse box. If you are experience in soldering, sometimes you can take these boxes apart and re-solder the broke trace. You will need to take a picture of all the fuse locations to make sure everything goes back to its original place. Let us know what you find.
Jul 12, 2025 at 12:26 PM
