Hi:
If you look at the last pic below. it shows the labor hours. As far as replacement, here are the directions. The attached pics correlate with the directions.
________________________________
2000 Ford Truck Expedition 4WD V8-4.6L SOHC VIN W
Procedures
Vehicle Engine, Cooling and Exhaust Engine Intake Manifold Service and Repair Procedures
PROCEDURES
Removal
WARNING: Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel-related components. Highly flammable mixtures are always present and can be ignited. Failure to follow these instructions may result in personal injury.
1. Disconnect the battery ground cable.
2. Relieve the fuel system pressure.
3. Drain the engine cooling system.
4. Remove the engine Air Cleaner (ACL) and the air cleaner outlet tube.
pic 1
5. Compress and slide the hose clamp and disconnect the upper radiator hose.
pic 2
6. Remove the accelerator cable snow shield.
1 Remove the bolts.
2 Remove the accelerator cable snow shield.
pic 3
7. Disconnect the throttle body cam.
1 Disconnect the accelerator cable.
2 Disconnect the speed control actuator cable.
3 Remove the accelerator return spring.
pic 4
8. Remove the accelerator cable bracket bolts and position the bracket and cables aside.
pic 5
9. Disconnect the main vacuum harness.
pic 6
10. Disconnect the throttle position sensor and engine vacuum regulator connectors.
pic 7
11. Disconnect the fuel pressure regulator vacuum line.
pic 8
12. Disconnect the vapor management valve vacuum line.
pic 9
13. Disconnect the differential pressure feedback EGR connector.
pic 10
14. Remove the nut and disconnect the brake booster vacuum line and bracket.
15. Disconnect the fuel lines.
pic 11
16. Disconnect the idle air control motor electrical connector.
pic 12
17. Position the EGR valve to exhaust manifold tube aside.
- Disconnect the upper fitting.
- Loosen the lower fitting.
- Disconnect the two vacuum lines.
- Position the tube aside.
pic 13
18. Remove the four bolts and remove the throttle body adapter.
pic 14
19. Disconnect and remove the Positive Crankcase Ventilation (PCV) hose.
pic 15
20. Position the power steering reservoir aside.
- Remove the upper bolt.
- Remove the lower bolts.
- Position the reservoir aside.
pic 16
21. Disconnect the eight fuel injectors.
22. Disconnect and remove the eight ignition coils.
23. Remove the generator.
pic 17
24. Disconnect the heater hose.
pic 18
25. Disconnect the two radio interference capacitors.
26. Remove the water thermostat.
pic 19
27. Remove the nine bolts.
pic 20
28. Remove the upper intake manifold.
1 Lift the intake manifold.
2 Disconnect the intake manifold tuning valve connector.
3 Remove the intake manifold and discard the gaskets.
pic 21
29. Remove the bolts.
pic 22
30. Separate the upper and lower intake manifolds and discard the gasket.
pic 23
31. Remove the bolts and the intake manifold tuning valve.
Installation
1. CAUTION: Do not use metal scrapers, power abrasive discs or any abrasive means to clean the sealing surfaces. These tools cause scratches and gouges that make leak paths. Use a plastic scraper only.
Clean all the sealing surfaces.
pic 24
2. Position the intake manifold tuning valve and install the bolts.
iPic 25
3. Position a new gasket and the upper intake manifold on the lower intake manifold.
pic 26
4. Install the bolts and tighten in two stages in the sequence shown.
- Stage 1: Tighten to 2 Nm (18 inch lbs.).
- Stage 2: Tighten to 10 Nm (89 inch lbs.).
pic 27
5. Install the upper intake manifold.
1 Position the new intake manifold gaskets.
2 Position the upper intake manifold.
3 Loosely install nine bolts.
6. Connect the intake manifold tuning valve electrical connector.
7. Install the water thermostat.
pic 28
8. Tighten the 11 bolts in two stages in the sequence shown.
pic 29
9. Connect the two radio ignition interference capacitor electrical connectors.
pic 30
10. Connect the beater hose.
11. Install the generator.
12. Install and connect eight ignition coils.
pic 31
13. Connect the eight fuel injector electrical connectors.
pic 32
14. Install the power steering reservoir.
- Position the reservoir.
- Install the two lower bolts.
- Install the upper bolt.
pic 33
15. Install the PCV hose.
pic 34
16. Install the throttle body adapter and the four bolts.
pic 35
17. Install the EGR valve to exhaust manifold tube.
- Hand-tighten the fittings.
- Tighten the upper fitting.
- Tighten the lower fitting.
- Connect the two vacuum hoses.
pic 36
8. Connect the idle air control motor.
19. Connect the fuel lines.
pic 37
20. Connect the brake booster vacuum line and bracket and install the nut.
pic 38
21. Connect the differential pressure feedback EGR connections.
pic 39
22. Connect the vapor management valve vacuum line.
pic 40
23. Connect the fuel pressure regulator vacuum line.
pic 41
24. Connect the throttle position sensor connector and the engine vacuum regulator connector.
pic 42
25. Connect the main vacuum harness.
pic 43
26. Install the accelerator cable bracket and the bolts.
pic 44
27. Connect the throttle body cam.
1 Connect the accelerator cable.
2 Connect the speed control actuator cable.
3 Install the throttle return spring.
pic 45
28. Install the accelerator cable snow shield and the bolts.
29. Connect the upper radiator hose and position the clamp.
30. Install the engine air cleaner and the air cleaner outlet tube.
31. Connect the battery ground cable.
32. Fill and bleed the engine cooling system.
Dec 26, 2020 at 9:29 AM
(Merged)
