wires
2006 KIA RIO
100,000 MILES • 4 CYL • FWD • AUTOMATIC
SILENTHILLDALE
  • 14 POSTS
what color wire for right headlight that only turns on with high beam?
Jun 20, 2016 at 9:12 PM
JDL
  • 16,098 POSTS
The orange wire at both headlamp assembly, is voltage. Those circuits are fuse protected, goes hot with the key on. Those fuses are in the interior fuse box. If you want to check for voltage, use a test-light or voltage tester. Your dimmer switch and headlamp switch controls the ground for headlamps. The high beam ground is brown. The low beam ground is red. If you have voltage, the problem is on the ground circuit, somewhere.
Jun 21, 2016 at 9:11 AM
SILENTHILLDALE
  • 14 POSTS
Thank you.
Jun 21, 2016 at 9:50 AM
