I am trying to fix my car. The ECU is showing as faulty but it has been replaced without fixing issue. i have been told the harness may be at fault and found a mouse had been living in the car also.
I have oil slick in the connector area so will use electrical spray as described in article.
Also, I will test the wiring for brakes. Do you have a wiring diagram for the car (it is actuary a SLK 200 but its not listed)? Think you may be using a SLK in the article as it looks just like my car.
Apr 24, 2019 at 5:57 PM
