The insulation is flaking off the wires in the wire harness from the crankshaft position sensor to the ignition module. Ford does not stock replacement harnesses. Where can I go for a replacement? I'm even willing to build the harness myself with automotive wire, a hi temp loom, and the correct connectors if I can find them. Where would I find replacement connectors?
Sep 29, 2014 at 2:35 PM
