The are 3 possible colors for the Fuel Tank Pressure Sensor signal wire coming from the fuel tank harness. I believe it is the Green wire that is the sensor wire going to the PCM. Can anyone verify if this is the correct wire? The connector under the car was filled with water and corroded, which I assume made the car throw a Check Engine light for "Fuel Tank Pressure High" P0453 code. Going to try and rewire the sensor wire and bypass the corroded connector. Just making sure I'm doing the right wire/color. Thank in advance..
Feb 24, 2026 at 3:02 PM
