Wipers do not complete a full sweep before stopping
2004 MITSUBISHI COLT
46,000 MILES • 2WD • MANUAL
WHITFIELD-GREENER
When you use the intermittent wipers, they do not complete a full sweep before stopping, so the effectively stop mid wipe. The slow and fast speed wipers work fine and park in the correct position when you turn them off. Am I looking at a new switch, relay or motor?
Jan 13, 2018 at 11:04 AM
KHLOW2008
  • 41,814 POSTS
I would say this is more likely to be a fault with the motor.
If it is the switch the wipers would not work.
When the wiper parks correctly with other speeds, that would almost completely rule out the relay as the cause.
The easiest way is to get a replacement motor and plug it into the wiper connector to test
Jan 14, 2018 at 10:32 PM
