Wipers not parking
1998 TOYOTA CAMRY
128,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
SWILSON11
The wipers work, they just will not park. When the switch is turned off, the wipers stop wherever they are in the cycle and do not park. I cannot seem to find where or if there is a relay that could be bad or if it is the multi-function switch that could be the problem. Thank you.
Jul 19, 2018 at 2:09 PM
You need to replace the wiper motor because the circuit board inside has gone bad not allowing the wipers to park.
Here is how it is done in the diagrams below
Jul 21, 2018 at 2:12 PM
SWILSON11
Thank you. I replaced the motor a couple days ago and solved the problem.
Jul 22, 2018 at 6:37 AM
Nice work, we are here to help, please use 2CarPros anytime. Sorry for the slow response we had a run on questions they got backed up.
Jul 22, 2018 at 12:09 PM
