Wipers not working
1998 MERCURY MARQUIS
98,000 MILES • V8 • 2WD • AUTOMATIC
CYNTHIA GILMORE
Wipers stopped working. When you turn them on all the do is wiggle up and down. Replaced motor and changed fuse under dash. Still doing the same thing. What else could it be?
Jul 26, 2018 at 10:13 AM
Is it possible for you to upload a video so I can see what is happening? To be honest, if you replaced the motor and it is getting power (12 volts), you may have a ground issue.
Check to see if there is 12 volts going to the motor. Also, make sure the ground is good or even make a new one.
Here are general directions for using a volt meter as well as a link that discusses checking wiring:
Try this first and let me know what you find. Also, a video would be very helpful if possible.
Jul 26, 2018 at 9:21 PM
