Is it possible for you to upload a video so I can see what is happening? To be honest, if you replaced the motor and it is getting power (12 volts), you may have a ground issue.
Check to see if there is 12 volts going to the motor. Also, make sure the ground is good or even make a new one.
Here are general directions for using a volt meter as well as a link that discusses checking wiring:
Try this first and let me know what you find. Also, a video would be very helpful if possible.
Jul 26, 2018 at 9:21 PM
