The front wiper's slow and intermittent speeds are not working
2018 FORD EXPLORER
87,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHINNAK
Only the high-speed working. I need to know, how to check wiring circuit and relay location.
Jul 4, 2022 at 11:12 PM
There are five fuses that run the system I would check those first (94, 95, 96, 37 and 13 on the inside fuse panel), here is a guide to help and the fuse locations, I have also included the wiper wiring diagrams so you can see how the system works.
If the fuses check out, I would do a CAN scan which is the future of automotive repair, you can get a CAN scanner from Amazon for about $30.00. here is a video to show you how and a link to a scanner from Amazon:
https://youtu.be/u-4syLc-ifQ
and
https://amzn.to/3OpAotj for the scanner
This guide can help:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Jul 5, 2022 at 5:10 PM
