If I understand correctly, you are getting power to the motor, but it won't run. Is that correct? If so, either we have a faulty ground or the motor is no good. However, I realize you have replaced it already.
If you look below, I attached the wiring schematic for the circuit so that you have a reference. I highlighted the ground for the wiper motor. The ground, G110, is attached to the body of the vehicle on the driver's side of the engine compartment. See pic 3
If you disconnect the connector at the motor, check to see if there is continuity to ground via the black wire.
See pics below.
Sep 15, 2023 at 9:33 PM
