will fourteen inch rims and tires fit on my car
2008 VOLKSWAGEN JETTA
66,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
KOC101
Will fourteen inch winter tires fit on this car? Fifteen inch five lug tires. Is there a manufactures recommendation? I already have a set of fourteen inch tires, all I need are the rims.
Oct 30, 2016 at 1:42 PM
CARADIODOC
  • 34,308 POSTS
If the car was available with smaller wheels and tires, there should be no problem with clearance, but handling will be compromised. If the outer circumference of the tire is smaller, the speedometer and odometer will not be in calibration. Also be aware that if you have anti-lock brakes, it is critical that all four tires have exactly the same outer circumference.
Oct 30, 2016 at 6:43 PM
