windshield washers do not work, passenger seat belt does not work
1997 MERCEDES BENZ 500SL
180,000 MILES
STANTON LEWIS
seat belt did work but is not working at present can not pull it out.
May 15, 2017 at 10:52 AM
STEVE W.
  • 15,113 POSTS
The seat belt could be the self tension-er, the part that once you pull the belt out and it latches you cannot adjust the belt without releasing it and letting it fully retract. If that has jammed you will probably need to remove trim to get to the re-tractor unit and free it. Or replace the belt assembly if it will not release.
Windshield washers could be the fuse or more likely the pump at the bottom of the tank has failed.
May 15, 2017 at 11:10 AM
STANTON LEWIS
That is not correct for seat belt it works some time but it an electrical problem.
May 15, 2017 at 11:34 AM
STEVE W.
  • 15,113 POSTS
If it is not the mechanical tension-er that is the problem, which is very common on them. Check that the child occupancy switch is not damaged or the wiring up to the re-tractor motor. The gearing itself sometimes fails but that usually just causes a lot of noise before it fails.
May 16, 2017 at 5:10 AM
